Enhancement Ideas: Add to Route and the "End"
Ran into two issues with a route I'd planned this weekend. The first was that if you add a new stop after your current "End" location (meaning you picked the end as the stop "prior" to the new one), the next waypoint (even if you've not reached it yet) is still labeled as the "End." For example, I was about 2 miles from my buddy's bike shop and decided not to go there (the "end") and instead go home. I edited the route, added home as a new stop, and clicked on the current "end" as the stop before. I then tried to skip the next waypoint, but it kept the name "End," which was a little confusing, as I'd just moved the "end" to a new location. I'm assuming that's because End is just a name for that stop from before, but perhaps it should be treated differently since it tends to have a special meaning?
Also, it would be super helpful when adding a new stop if the UI auto-zoomed back to the current route, or at least the section of the route which remains. You get prompted to select the waypoint before the one you're adding, but depending on your zoom level, you won't see anything of that route (happened 2-3 times to me over a couple of days).
Understand what you mean. I will take a look at this during fall/winter while I'm migrating Scenic to the new HERE map framework.
Hi TheBigBonedBiker.
Instead of setting another Stop:
Edit route and select your home as „end“. Save changes.
Senic will route you to the new „end“.
Regards, Mex
TheBigBonedBiker has reacted to this post.
TheBigBonedBiker
