Enable easy switch between Show Destination and Show Next Stop
Riding the last couple days with several buddies, and wishing there was a tap option on the nav screen to toggle between the day's ultimate destination and the next stop. Both matter, but unless I'm missing something I have to burrow into Settings to see the other.
In Settings > Navigation & Tracking > ‘Show distance & time to’ you can set this to ‘alternate’ Than it continuously switches between next stop and destination
Also you can tap the bottom ETA bar to see the route timeline.
If you are talking about the "Show Distance and Time to" so that the Distance, Time to, and Arrival time fields show either Destination or Next Stop... You can choose Alternate. That will cause those fields to alternate between Destination and Next Stop (at about a 2 second rate).
Might not be exactly what you'd like. You might prefer to have some item/button that you can easily press on the screen to manually control this. Perhaps the alternative viewpoint is that the Alternate option eliminates the need to press anything and therefore minimizes required interactions and resulting distractions. I can see both points of view.
Quote from Guido on 07.04.2023, 14:42
Jinx.
