Edit route during navigation
Quote from Deleted user on 11.04.2023, 07:16I am using Scenic navigation with follow the line. When I edit the route during navigating by adding new Via points the original line is still there, it is not removed. During driving it shows that I need to eg turn right with an arrow. But if the original route was to turn left, this line is still there. This is a bit confusing. Is this a bug or a setting ?
Quote from Guido on 11.04.2023, 08:14This sounds like a bug. In fact with ‘follow the line’ navigation, route editing should not be possible during navigation. So the bug really is that Scenic is not giving you a warning that route editing is not possible with follow the line navigation. Also it should not show you the turn-by-turn arrow.
Ill have a look at that for the big update I’m working on.
This is probably not the answer you were hoping for, sorry.
