Duplicate route on iPad
Quote from Plus 4 on 03.03.2024, 01:29When I click on a saved route on the iPhone, some buttons (Navigate, Share, GPX export, ...) are displayed below. I miss these buttons on the iPad (I usually plan on the iPad). Are these options not available on the iPad (I would currently like to duplicate a planned route) or can these buttons be found elsewhere?
Many thanks and best regards,
Plus 4
Plus 4
Quote from Barkinmadd on 03.03.2024, 07:59It's funny that you'd ask this as I couldn't find the duplicate button on my iPad yesterday and it turns out the entire Scenic 'window' scrolls upward to reveal (in my case) a second row of buttons. This is on a iPad Pro 12.9" display so yours may differ but if you touch to the right of the top buttons (or the route title area) you should be able to drag up to see those lower buttons.
Quote from Plus 4 on 03.03.2024, 10:43Thank you very much! That's the solution (I'm using an iPad Pro 11").
The unusual thing is that the bottom toolbar only appears when you tap and scroll the window by the top toolbar (otherwise you just move the map).
An additional button in the upper toolbar that brings up the lower toolbar might be helpful here.
Quote from Barkinmadd on 03.03.2024, 12:39Glad I could help. Yes - it might be useful to have a visual indicator to make access to the missing buttons easier. I my case, only the duplicate and delete buttons were missing but the buttons that were visible (at the bottom) were slightly cutoff which was my clue that there was more to the view than could initially be seen.
