Drifting position indicator
Quote from Rainbow57uk on 24.02.2025, 03:27Hello Guido,
I’m seeing an issue in the Scenic app that I am not seeing in other navigation apps. I have attached two videos to demonstrate the problem. The videos were taken one after the other using Apple Maps navigation and Scenic. Both apps were navigating along the same road and were utilising Apple CarPlay via an iPhone 11. The phone was in the exact same position with the switch between apps done via CarPlay. On the Apple Maps video, the position indicator is locked on the road and shows no deviation. With Scenic the position is shown way off the road, eventually drifting back onto the road. Just prior to this, the position indicator had been oscillating back and forth across the road. It would appear the Apple Maps navigation software is doing some calculation to snap the position to the road being navigated.
Hello Guido,
Quote from Guido on 24.02.2025, 07:21At this moment, Scenic only snaps location if you are on the route. Even though I see the route line, I don’t think Scenic thinks you are on the route. Otherwise the route would turn gray behind you. What is your detour behaviour setting?.
Quote from blackhawk1618 on 24.02.2025, 07:45+1
This happens with me quite often. Why Scenic don't think that I am not riding on the route, though I use the default riding mode most of the time.
+1
Quote from Rainbow57uk on 24.02.2025, 08:50My detour behaviour is set to “Don’t recalculate”. It is set to that because I would get a lot of recalculations going on. I’m in a car so the gps signal may be weak but that should be the case for Apple car play. This occurred around two weeks ago so v4.10 or 4.11 would be active.
Quote from Guido on 24.02.2025, 09:01OK. Thank you. I just did some testing myself during my daily ride taking kids to school. There is a bug where Scenic doesn’t recognize you getting back in the route, which also prevents the snapping to the route. I’ll try and get that fixed for the next update.
