Divide the route into fast and curvy
Quote from Rockstar Pics Ducati on 25.07.2024, 03:23Hello everyone,
i would like to create a route that should initially at the beginning highway (fast) and then, from a certain point, should lead over land (curvy or similar) to the specified destination.
Unfortunately, I haven't figured out how to set this up.
I can add "via" or "stops", but the route setting only applies to the entire route and not to a selected section.
Or does this not work with this app?
I've only recently become a premium user.Best wishes
Benny
Hello everyone,
Best wishes
Benny
Quote from nick123123 on 25.07.2024, 03:58It’s unfortunately not an option as you have noticed.
Quote from Rockstar Pics Ducati on 25.07.2024, 04:05Yes…sad but true 😕
Yes…sad but true 😕
Quote from nick123123 on 25.07.2024, 04:52Nice profile pic btw, is that your bike?! Wow
Quote from johansw on 25.07.2024, 05:13The easiest way to achieve your route is to 1st set it to curvy, and then, for the other part, take the highway using the viapoints.
Quote from Rockstar Pics Ducati on 25.07.2024, 05:46Quote from nick123123 on 25.07.2024, 04:52Nice profile pic btw, is that your bike?! Wow
Yes, that`s my little Pani 🙂
Thank you. 🙂
Thank you. 🙂
Quote from Rockstar Pics Ducati on 25.07.2024, 06:09Quote from johansw on 25.07.2024, 05:13The easiest way to achieve your route is to 1st set it to curvy, and then, for the other part, take the highway using the viapoints.
Yes, but that's what I try all the time.
How do I assign a different route option to the second section of the route?
Quote from Guido on 25.07.2024, 07:04Hi guys, I'll quickly jump in... there are several other topics on this. Here's one: https://scenic.app/forum/topic/different-routing-profiles/#postid-145
In short... at the moment, Scenic's routing algorithm does not allow multiple routing modes per route.
I recommend the same as what Johan already suggested more or less:First: Set start and end for the curvy section, and generate curvy route
Second: Now add start where you actually want to start.I know it's not the answer you were hoping for, but, until multiple routing modes are supported, this is the best recommendation I can give. Hope this helps.
Quote from Rockstar Pics Ducati on 25.07.2024, 07:09Quote from Guido on 25.07.2024, 07:04Hi guys, I'll quickly jump in... there are several other topics on this. Here's one: https://scenic.app/forum/topic/different-routing-profiles/#postid-145
GuidoHi Guido,
Thank you, I will use this method if nothing else works.
That would be a good suggestion for improvement for the development department 🙂
Best regards
Benny from Germany
Best regards
Benny from Germany
Quote from HyperMulti on 25.07.2024, 09:40I've found that I need more control over the routing, so I use something like footpathapp.com, which has a great web planner, and then import that into Scenic for final edits & onbike routing.
Quote from nick123123 on 25.07.2024, 10:22Quote from Guido on 25.07.2024, 07:04Hi guys, I'll quickly jump in... there are several other topics on this. Here's one: https://scenic.app/forum/topic/different-routing-profiles/#postid-145
GuidoHi Guido
I know Kurviger offers the mixed curvature option - I guess they keep this to themselves and don't offer it to you via an API?
Hi Guido
Quote from Guido on 25.07.2024, 11:54correct
correct
