Forum breadcrumbs - You are here:Scenic ForumUsing ScenicDistance to Turn Bug
Over the last couple of months on a number of occasions the distance to turn disappears while navigating a route.  Once the turn has been completed the distance to next turn returns. Unfortunately there is no pattern to when this happens and it doesn't always happen on every ride. Today when it happened I turned off the road enough to get re-route to activate and recalculate the route and of cause the distance to turn returned. I am guessing that this sort of bug would be very hard to find because there seems to be no pattern to it. Is there any way to force a recalculation of your current route ? Obviously I do not want to skip a waypoint / stop which would cause a recalculation but this would also change the planned route.
Hi Peter,
Im aware of this issue and looking into it. What seems to help (as a workaround other than deviating from your route), is to turn off your phone (lock the screen) and then turn it back on again. Of course this is not very handy while riding, so maybe deviating is a better option.
PeteRT has reacted to this post.
PeteRT
Thanks Guido I will try this next time it happens. Been using the app a lot recently and it has been working well.
