Distance to Next Turn/Stop Option
Quote from vennbrewer on 05.06.2023, 15:11Hello,
Is there a way for Scenic to only display the distance to the next change in direction or the next stop rather than to the next via point? Many times during navigation it will display the distance to the next via point instead of how long I'm going to be staying on a road for. The vast majority of the time, the via points I use are exclusively to force a route one way or another and, once I'm navigating, I have no interest in the via points anymore - I only need to know when the next turn or stop is going to be. Does this already exist? If not, might it be possible?
For end-user context, sometimes I end up staying on one road for 300 miles but there's a via point somewhere in the middle of that 300 miles. It's more useful for expectation management to know you're going to be going straight across South Dakota with no directional changes than to countdown the miles to a via point that doesn't really mean anything, and then learn you still have another 200 miles on that road to go!
Thank you so much! Scenic is awesome!
Kyle
Hello,
Kyle
Quote from Guido on 05.06.2023, 16:05Hi Kyle,
Have a look at this post. It explains why it’s happening:
https://scenic.app/forum/topic/voice-notifications-skipped/#postid-4151Im working on a big update, on which this behaviour will be resolved all together no matter how much via points you have.
Hi Kyle,
Quote from vennbrewer on 05.06.2023, 16:11Fantastic. Thank you so much, Guido! I'm very happy to continue using it as-is in the meantime.
Cheers!
Cheers!
