Display lag and displayed driving direction (heading)
Quote from ElCid on 03.07.2024, 01:52Maybe i am the only one with this problem, but my display (IOS and/or Carplay) My position jumps every 2-3 seconds. There is no smooth moving of the map as in every other navi-software. Also my display shows me not in driving direction. (in map view) are there any solvings? My heading should force the map to turn. (extrapolating does not solve this phenomenon)
thanks for any advices in advance
G.
G.
Quote from Guido on 03.07.2024, 06:08Scenic works a bit different in this perspective. Because Scenic always records your ride you have to actively start a ride/navigation. You do this by tapping the “start ride” (or “navigate”) button in right hand side of the top toolbar. Some CarPlay systems hide this toolbar after a few seconds. To make it appear, tap the screen or use your vehicle controls.
While in the main CarPlay screen, location updates are limited and less accurate (to save battery). And the map is always north up in he main screen too.
Quote from ElCid on 07.07.2024, 12:44Thank you, when i tap on 'start ride' then everything is ok. Sorry, I am a new at the software.
All good now
cheers and thanks for your fast reply.
Gerald
All good now
Gerald
