Discard ride
Quote from jqsfoto on 15.11.2020, 00:45Not sure if I just don’t see existing option/ post about it, but the discard/save/resume ride pop- up that can’t be accessed by the wunderlinq wheel is the reason why I most often choose another gps integration on wunderlinq. Is it possible to have an opion in settings to choose, a default option, get the pop-up to disappear after 10 secs or at least make it so that wunderlinq wheel movements can choose an option. Yes I know we must pull over & take off our gloves etc, but it is very frustrating when you select an “one button item” on wunderlinq such as “take me home”, directions to a filling station or even just want to call up nav app to see map without actually typing a destination and it seamlessly open app just to be confronted with a pop- up that you have to pull over for or struggle with touchscreen - while most other tasks on both scenic and wunderlinq can be done with the wheel.
Quote from Guido on 15.11.2020, 11:36It should work without need fort touch screen. I’m on a motorcycle trip now myself without kuch signal. So can’t test (only have WunderLINQ test setup in office).
ket me take a look when I’m back.
to confirm:
- in WunderLINQ you select ‘take me home‘
- scenic opens
- now you need to touch screen to start navigation, while you would expect to be able to start nav with WunderLINQ wheel.
Is this correct?
to confirm:
- scenic opens
Is this correct?
