Disable Display when Rauning
very good App, we use it very often with actual iPhone
At the momentwe are in norway and its raining very often 🙄
Problem is when waterdrops hit the display, buttons can be pushed and you cant see your route. If you have „touchy“ gloves, you can go back, but it hapens very often and using the App while driving is dangerous.
Maybe its possible to lock touch by Action-Button oder Triple-Touch or something like that?
Thanks and BR
Alex and Heike
Hi Alex and Heike,
Have you tried "Guided Access"? It's an accessibility setting from Apple, that can be activated by triple pressing the on/off button on your device. You'll need to set it up first, but once done, it's easy to activate and deactivate: https://support.apple.com/en-us/111795 , and it works with any app, not just Scenic.
My goodness - are there no limits to what can be done by Scenic and/or iPhone??? Never knew about this one!!
like ever … first class support 👍🏻
Did also not know this feature, problem solved 👍🏻
BR A+H
Another fast Question, need no changes 😂
I have installed the App new, all settings gone…. problem is now, that the zoom increases very slow … I can see a roundabout when I'm in it, the app zooms too late...
I tried speed-dependent zoom, but no matter how I set it, it doesn't work...
i would like to see the roundabout or a turning before I pass 😂
The zoom behaviour didn't change for quite a while, so I'm not sure what changed for you. Perhaps try chaning the 3D camera angle? (Settings > Navigation and Tracking). More info here if you've not already seen it: https://scenic.app/help/speed-based-and-turn-based-zoom/
CrazytravellersWZ has reacted to this post.
CrazytravellersWZ
Quote from CrazytravellersWZ on 11.06.2024, 23:26
Is this a common problem?  I've heard about it, but I've never experienced it myself... even when riding in the rain, without anything protecting the iPhone screen from the drops.  Does it have to be raining very hard?
It depends on your device (newer devices can handle it better), and on the size of the drops. Source: https://www.quora.com/Why-does-a-little-bit-of-water-on-your-phone-make-the-touchscreen-operate-so-poorly-especially-when-typing
Its an iPhone 15 pro behind the screen of a 1250 GS … normal rain on a motorway …. and waterproof gloves without touchy fingertips … horrible 😆
Thanks guys!
Quote from Guido on 12.06.2024, 12:14
worked for me, thanks a lot 👍🏻
