Direction cues when navigating to route
Hi @guidomm
Really enjoying the app and using it quite a lot.
I had created a round trip route and was starting off. Due to the Saturday morning market, I couldn’t take some of the initial turns. I ended up in the village centre a little confused. There were a number of problems:
1. it didn’t seem to reroute me, maybe because I was on streets I technically shouldn’t be on
2. I could see the way out and the way back, but I couldn’t tell which was which as both were identical colours
3. I couldn’t see the direction of either route (way back, way out) so I couldn’t tell which direction to turn onto the blue highlighted route
4 the sound that scenic makes when you are off the route makes a wildly stressful sound that really does not help
Some things I think would help
- clear direction cues - arrows for example that always appear on the portion of the route that’s visible on-screen
- if the way out and way back are visible on-screen at the same time, have them different colours
- direction alone is not enough if you are disorientated and have both way out and way back visible on-screen because you don’t know which is which
- some way to permanently disable all and every sound. I have sounds disable in sounds and haptics setting yet it still made this terrible sound while trying to figure out where I needed to go and I couldn’t figure out how to stop it
GHJ has reacted to this post.
GHJ
That could be. If the road you are on is not a mapped road, then it can't really reroute you... or perhaps you have recalculate on detour turned off? (Settings > Navigation & Tracking > Detour behaviour)
Working on that. Will be added later this year.
OK. Makes sense. I'll see if I can add that too, while I'm working on the direciton arrows.
Did you turn off the recalculate sound in Settings > Sounds & Haptics, and you were still hearing the recalculate sound?
Turning all sounds off is already possible: Tap the speaker button in the navigation menu to cycle through "Sound ON", "Alerts only" (alerts include the recalcualting sound), "Sound OFF".
Burki968 has reacted to this post.
Burki968
Thanks for the replies. Indeed, I hadn’t disabled the route recalculation sound. I would have thought the sound effects setting was a master setting, so maybe a little unintuitive.
Thanks again!
