Forum breadcrumbs - You are here:Scenic ForumUsing ScenicDirection arrows
Direction arrows
Any chance to get dual direction arrows on a road that will be ridden in both directions?  Currently when planning the arrows only go in one direction.
Sorry. That’s not possible. Limitation of the map provider framework.
What you could do, is make the route line more transparent (Settings > Appearance & Colors), so the arrows below show more.
thank you for the response. That will work. Glad there is a work around.
