Different Routing Profiles
Quote from Bobbo on 16.04.2020, 03:41Fist of all.... I like the Scenic App! What a benefit!
I normally plan routes in the App itself and have the computer in parallel.
One question.... I am wondering If I can set different route profiles for different sequences of one route. For example I want to have a first ride on the motorway and have a stop then. The second sequence should be a nice curvy route and maybe the last one should me bring home again fast on the motorway.
I don't want to plan x different routes to have an idea of the total kilometers and the estimated time.Is this possible and if yes, how would be the adjustments?
Thanks and have a good one... Alex
Quote from Guido on 16.04.2020, 16:19Hi Alex,
Unfortunately you can set only one routing mode/profile per route. This is a restriction from the routing provider that Scenic uses. Can't change that I'm afraid.
There is a workaround though.. not ideal, bit it will work in most scenarios... simply create a route (I'd recommend with Efficient routing mode) and then drop via points or stops to force the route to take certain roads.
Not ideal, but might work for you.
Cheers, Guido
Hi Alex,
Cheers, Guido
Quote from MacGyver on 19.04.2020, 17:18Hello Alex
I'll make it so I put a few points on the highway. The points are exactly between the entrances and exits of the highway. This way the route planner is forced to drive right through them.
If you set the point somewhere on the motorway, it is possible that the navigation system will lead you off the motorway and back on the motorway again, because then you have already made a few curves.
One more tip: make sure that you choose the exact direction of the motorway, otherwise you may have to drive the route twice.
Try that out.
DLzG
Viktor
Hello Alex
Try that out.
DLzG
Viktor
Quote from Bobbo on 20.04.2020, 05:31Quote from Guido on April 16, 2020, 16:19Hi Alex,
Cheers, Guido
Hej Guido,
thanks for you reply. That's how I usally do it but I wanted to be sure that there is no other way. Thanks.
Alex
Cheers, Guido
Hej Guido,
Alex
Quote from Bobbo on 20.04.2020, 05:33Quote from MacGyver on April 19, 2020, 17:18Hello Alex
Try that out.
DLzG
ViktorHej Victor,
I will try this (once the Bavarians let us drive again 'cause of the Virus). As you wrote I set randomly the points on the motorway. Thank's for the hint!
Have nice rides and a good day.
Alex
Try that out.
DLzG
Viktor
Hej Victor,
Alex
