Desktop app - making routes & unpaved roads
Quote from greg2112 on 01.10.2024, 16:36In version 3, when using the Power Planner, dirt roads were a different color on the static map and it was extremely helpful in route creation. Also, in spite of having turned on "avoid unpaved roads", it will let me build a route onto a known dirt road with no warning or change in the color of my created route as a warning. This is a necessary feature to create usable routes.
I create routes by choosing my own path and dropping waypoints/vias to force my path. I'm finding when I create a route, it takes illogical and arbitrary paths to the pin I dropped. For example, when dropping a via pin on the same road further ahead, it will choose a path away on another road and on a longer and illogical path to get there. If I move the via pin closer, and use more of them (excessively I might add), it will work but on a day-long ride I will end up having hundreds of vias.
Quote from Guido on 02.10.2024, 10:46Dirt road visualization will come back with the Map Style Customizer. More info here: https://scenic.app/scenic-4-faqs/
Could you send me a screenshot and the name of the road where the excessive via points were necessary? Not sure about cause. What was your routing mode when this happened?
Quote from greg2112 on 03.10.2024, 09:02Quote from Guido on 02.10.2024, 10:46Dirt road visualization will come back with the Map Style Customizer. More info here: https://scenic.app/scenic-4-faqs/
I was using the default routing mode. I will recreate it and post a screenshot.
More important to me of the two issues noted are the lack of color distinction in unpaved roads and no alert/warning when I have routed onto an unpaved road, in spite of having "avoid unpaved roads" enabled.
Thanks for all your hard work and commitment to the product. Your accessibility and quick responses are evidence to your commitment. I come from an IT background and understand the pains of change, change management, and development.
Quote from KenJohnson15 on 20.10.2024, 20:49UNPAVED ROADS FEATURE
"More important to me of the two issues noted are the lack of color distinction in unpaved roads and no alert/warning when I have routed onto an unpaved road, in spite of having "avoid unpaved roads" enabled."
Agree. This is a very important feature. I led a ride through West Virginia today. Not realizing that the feature was removed resulted in travel down a rough unpaved road. The ride then needed to backtrack. Very unfortunate.
Also, greg2112 refers to enabling "avoid unpaved roads." Is there a way to do this in Version 4?
I don't see anything in the scenic-4-faqs related to unpaved roads.
