Forum breadcrumbs - You are here:Scenic ForumUsing ScenicDeleting wrong waypoints
I discovered a wrong behaviour in planning mode when I was replanning a route. My route has both Vias and Waypoints.
Error reproduction is as follows:
- open route in planning mode
- pull up the list of waypoints
- with Vias “hidden”, delete a waypoint which is after one or more of the (hidden) vias (for example waypoint 5) - swipe and delete
Instead of deleting the waypoint 5, it deletes the 5th point in the list (including vias)
With Vias visible this function is working correctly.
That’s a bug. You shouldn’t be able to delete when via points are not visible. Thanks for pointing my attention to this.
