Delete/Skip VIA option not appearing on screen
Quote from tk901399_Forum on 20.05.2024, 08:21Hi I have been using Scenic since 2017 (i think) and have been lifetime subscriber since then.
I recently have had an issue where i have created a route, and during following the rote i decided to drive some of the route via motorway to save some time.
in both cases when i ignored a via and the App recalculates as well as presenting a "detlet via" button. but then that button is not presented for the next vias. In both case i had to stop the bike fiddle around for some time not findig anywhere i can access the "detlet via" button. So i have to close the routing and re-start it, for what ever rason then i cet the "detlet via" button again and again as i start skipping the vias.Is ther some place in the app i can get access to the "detlet via" option?
Quote from Guido on 20.05.2024, 09:54Hi @tk901399_forum,
When you delete a via point or stop with the delete via button, then, after you start moving again, the button to delete the next via point should appear. Perhaps the key message here is "after you start moving again". Scenic needs to receive at least 1 coordinate after you delete a via point before it can display the button to delete the next via point.
Alternatively, what you could do, is go into edit/overview mode (move the map slightly to go into that mode), tap on the markers you want to remove and remove them like that.
Hi @tk901399_forum,
Quote from tk901399_Forum on 20.05.2024, 10:48Thank you Guido for very quick reply 👍
Both of the times I was in motion when I clicked the delete via option. So I assume there might be a bug as it is not intended to work this way. Now if I am the only person who have experienced this then I am not so sure.
Anyway I'll try your work around to see if I can at least save the entire trip instead of only the part after the issue.
Best regards
Tore
Best regards
Tore
Quote from Guido on 20.05.2024, 11:05Hi Tore,
You are the first one mentioning this, but that doesn't mean that there is no bug. I will investigate further and try to reproduce this issue here. If I find anything, I will report back.
Hi Tore,
