Forum breadcrumbs - You are here:Scenic ForumUsing ScenicDelayed Voice Prompts
The settings say that the final voice prompt should start 150 feet from the turn at speeds lower than 37mph, but I often find it prompts after I started to turn. Is there a correction in the app I can make?
That’s very late indeed. Is your sound coming through a Bluetooth connected speaker / headset? If so, this could cause a delay. Not sure what else could cause this.
What you could do (more of a workaround) is disable that final voice instruction, so at least you don’t get confused).
