Default routing mode for carplay
Quote from DarrenS on 31.01.2025, 01:42Is it possible to set a default routing mode for when using CarPlay? Or at all?
I often now use scenic off the bike and hence set the route to walking. Easy to do, just a click of a button.
however if I do not remember to set it back to bike/car before I get back to the vehicle when I do a route or destination in car play it still defaults to walking.
I can see no time when someone would want walking routes in car play. This will take you down one way streets for one and is dangerous if you do not realise it has given you a walking route.
when you do realise you have the hassle of stopping the bike, disconnecting CarPlay, getting gloves off, getting phone out, going into the app, setting routing mode, phone back away, gloves back , etc.
there needs to be a way to set a default routing mode for when connected to car play or for the app overall.
Quote from Guido on 31.01.2025, 06:28Hi Darren,
I understand
Adding a routing mode selector on CarPlay is still on this list.
Meanwhile, the process to activate Scrnic on your iPhone is a bit easier. Simply switching to another app on CarPlay, will make Scenic active on your iPhone (I.e. the back screen will make place for the normal UI if Scenic is not the foreground app on CarPlay)
Hi Darren,
I understand
