Date/time on shared route not updating
When sharing a route via a URL, the date and time stated on the webpage is the point in time I've imported the route from Kurviger, and not when it was last edited. It would be helpful to know when a shared route has been last updated, instead of an initial creation date.
Example: I've updated this route just now in Scenic, but the URL says it's from a month ago:
Thnx for the support!
Eddy
Hi Eddy,
This is actually text. It's the default route description when adding a kurviger import. You can change the description through the app: select the route from your route list, and then tap the route name or description to change it.
That makes sense, I never noticed the description when renaming routes. Thanks!
For me it would be kind of helpful to know what the last save date is when sharing routes, though  🙂
Eddy
I understand. I'm working on a bigger redesign at the moment, and will add this.
