Customize/modify calculated route
Quote from iSilentP on 01.07.2022, 16:46When I pick a location and choose “Start Navigation” the resulting route is not always the one I would like to follow. Is there a way to modify similar to Google Map by dragging a portion of the highlighted route to recalculate using the new path?
Quote from Guido on 01.07.2022, 16:53Yes. More or less. The dragging and dropping like google maps is not supported, but by placing via points you can alter your route as well.
There are a few ways to do this, depending on which screen you are:
In the Power Planner you have most control in this. There you can plan the route and drop as many via points as you want. (you can't drag and drop, but placing via points using the crosshair and buttons has the same effect). I recommend looking at the routes section of the tutorial video ( https://scenic.app/help/scenic-detailed-tutorial-video/ ) for that (it's still the old version of scenic but power planner is 95% the same).
In the main screen (before you tap 'Start Navigation') the route is already calculated so you can see it. By tapping on the location on the map where you want to add a via point, you can add a stop or via to the route as well.
In the navigation screen (so after you tapped 'Start Navigation) you can go to edit mode by double tapping the map. Once in edit mode you can add via points in the same was as in the main screen.
