Forum breadcrumbs - You are here:Scenic ForumUsing ScenicCustom Map Colours
Custom Map Colours
Is there a way of seeing the custom map you can create after changing the road, land colours etc? I use Apple CarPlay and view my maps and routes on the Chigee AIO-5 Lite unit.
Not directly on CarPlay. You’ll have to set the custom map style as default. To do this, tap the custom map style and then choose “set as default for light appearance” or “set as default for dark appearance”.
Perhaps I’m missing something. I don’t seem to be able to get the custom map to show up on a CarPlay device. Also, the default map doesn’t have a lot of contrast between the background and the roads.
Have you tried my answer above your post?
