Custom icons for Location Folder
Hello,
I have multiple folders in Scenic for locations for example restaurants, campgrounds, hotels.
It would be nice to have the ability to select a custom icon like fork & knife, tent and bed to use the examples above.
Having this ability would make it easier when to identify exactly what location is, or isn’t by looking at the map. It would also be nice to have a notes field for each location to capture phone numbers, web sites and more info and have the ability to access the info from the map.
Thanks,
John
Hi John,
I will add that the list
Meanwhile, you could set up these kind of locations as a POI group. You can choose icons for a POI group. You do need to know the coordinates of these locations though. And you can not add descriptions for POI groups.
you can however add descriptions for a location: simply tap the location from your location list and then tap the title There you can also enter the description
Guido,
Thanks for the suggestion and like always the prompt reply. I’ll check out that option.
John
