Curvy Routing Timeout
Quote from JesterPilgrim on 08.12.2021, 10:52Hi there. I'm trying to plan some routes in Spain (I've downloaded the offline map) but whenever I set routing to anything "curvy" (powered by Kurviger) I am getting a timeout error. Curvy routes are working fine in my own area (UK). Any ideas what's going wrong?
Using 3.04 on iOS 15.1
Quote from Guido on 08.12.2021, 11:42Could be a number of reasons, but my guess is that Kurviger is suggesting roads that Scenic doesn’t know or doesn’t think you are allowed on.
The way it works:
- You generate a curvy route between start , end and possibly some stops.
- Scenic sends those coordinates to Kurviger- Kurviger sends back a longer list of coordinates.
- Scenic feeds that list of coordinates to its own routing algorithm.
- If some of those coordinates are not on roads that Scenic knows, it tries to calculate but it can’t. It shouldn’t result in a timeout though. It should give you a message like ‘route can’t be calculated’.if it’s really a timeout, then it could also be a connection problem. Crunch route generation requires a connection (to connect to Kurviger).
To double check to see if it’s the first thing I mention, you could try and generate the route on the Kurviger website and then use the ‘send to scenic’ button on their site.
The way it works:
Quote from JesterPilgrim on 08.12.2021, 12:52Thanks for the quick reply! It was definitely the start point that was the problem... I moved that and it worked 🙂
