Curvy option routes through residential areas
Quote from smoeke on 03.04.2025, 08:41The curvy option oftens routes through residential areas. Those routes might be slightly more curvy than the main roads, but often this is related to residential area layout with approx. 90-degree turns where you often have to stop before turning.
Those route parts are often not really useful. Maybe it could be an option to try to reduce such routing through residential areas for curvy routing (by avoiding residential roads with some negative weigth etc.).
I understand that this will not be possible for all cases, but I think it could be reduced to get a more fluent curvy routing and not to bother residentials by going though their areas, when it is not really necessary.
The last one is really funny though, because it cuts off the real curve replacing it with a more straight path and two turns. I am also not sure if this would be more like an private road (which would be also an map data issue).
Link to the route I will sent via message/mail.
Quote from Guido on 03.04.2025, 15:16I understand what you mean. Unfortunately I have no control over the curvy routing algorithm. Scenic uses a 3rd party provider for that for the moment. I know they are aware of this.
