Create Route from Web App?
Quote from Rambler358 on 20.03.2020, 15:05New user here wanting to try out the features of Scenic. Is it possible to create a route in the Web App? I'm not seeing a way, or how to do this. Thanks!
Quote from Guido on 20.03.2020, 15:48The WebApp is very limited at the moment. You can only import routes in various ways. Next to that shared routes and rides can be added through the WebApp: https://scenic.app/knowledge-base/sharing-routes-rides/
Until that time I recommend to use one of the route planning tools that Scenic integrates with. There are various, depending on your routing needs. If you have a favourite site/program already, and that one support GPX export, you can continue using that one and just import the GPX files in Scenic (see import tab for various options).
If you don't have a favorite route planning tool yet, I can recommend these 3:
- Google Maps (for basic route planning needs... easy to use... integrates through Scenic WebApp
- Furkot (for extended route planning needs... steep learning curve... integrates through Scenic Import Tab
- Kurviger.de (for basic route planning needs including curvy routing... integrates through 'Send to Scenic' button on Kurviger site.
