Crash when selecting/following a track in carplay
love the app, especially due to the fact that I can use carplay on my Honda but now I was running into an issue where I am not sure whether it’s my fault or the apps fault.
When selecting an imported GPX track in CARPLAY and then starting the navigation Scenic will crash and reset. On my iPhone it works flawlessly. What can I do in order to have tracks shown also in CARPLAY?
Thx & cheers
Ralf
Hi Ralf,
This sounds like a bug in Scenic. I'll need to take a look at the crash reports. Could you make sure you have 'share with App Developers' turned ON in iOS Settings? (otherwise I won't get the crash report):
iOS Settings > Privacy & Security > Analytics & Improvements > Share iPhone Analytics ON > Share with App Developers ON
After you've turned this on, make the app crash again.
I'm working on a big update now (new HERE map framework), rewriting a lot of the code. I'll probably implement the fix for this in this new version (as it would be a waste of time to try and fix it in the current version). It will take a little while though until the new version is ready. Probably a month, maybe 2. Sorry.
Hi Guido, thx for responding so quickly 🙂
The required iOS settings were already active when today the crash happened. Hope you can find the event.
Ralf
Hi Guido
Short update regarding this topic. I‘ve fiddled around with some tracks in Scenic and voila, I succeeded in showing the tracks also in carplay. It is very simple, I have to select the track and start the navigation in the iPhone BEFORE starting carplay and then the track will be shown in carplay and tracking is happening at the same time without any issue. This is a very good workaround, so my TET navigation for the time being will be based on Scenic 🙂
That’s good to hear! Thanks for posting this solution. A great workaround until I have this fixed in the big update!
Enjoy the TET.
DasOrakel has reacted to this post.
DasOrakel
