Forum breadcrumbs - You are here:Scenic ForumGadgets & GearControl Commands
Control Commands
Hello riders,
I have upgraded my bike with the Barbutton Handlebar Controller. As I want to customize my buttons, I tried to adapt the code of the controller. Unfortunately, I then noticed that Scenic does not implement the commands directly, but that the buttons are controlled separately via settings. Unfortunately, the selection is rather inadequate (as I have already assigned some functions to the 4 other buttons).
Is there an additional function that can be entered on the keyboard to control Scenic?
Or can the map be moved with the keyboard?
Thanks for your answers
Hi @keppy217,
Panning (moving) the map with barbuttons is not implemented in Scenic. This is because Scenic also works with other controllers (which have less buttons). It's on the feature request list to add that in the future, but it will be a while. Here you can find more info on barbuttons: https://scenic.app/help/handlebar-controllers/
