Forum breadcrumbs - You are here:Scenic ForumUsing Scenicconnecting tracks
connecting tracks
I recognized that whenever I change something, I have to stop the current track and save that. At the end of a day I have e.g. 5 tracks and would like to combine them to just one. Is that possible or do I have to send all of them to my pc and connect them with QVX (which I use) or basecamp or whatever.
In case they cannot be connected in Scenic, is there at least a way to send more than just one track by mail?
Thomas
What are you changing? For most changes you don't need to stop the current track.
Of course when I do tests it is a bit more often than usual, however carplay does not allow that many changes. I have changed the settings of the speed controlled zoom to find a good solution oder changed the routing to very curvy wich is impossible when using carplay. I also did not find a possibility to add another via piont although there is a carplay function „add stopp“ but it did not work and therfore I had to stop and use my phone for those changes. In the end I had 4 Tracks and needed to connect them.
Thomas
Hey,
will it be possible to connect different tracks?
If you are on a long trip, serveral days, usually the trip of the day will close after stopp tracking or after arrival of a destination.
It would be nice to connect some trips to have a overwiew of all trips together. Are there plans for it?
There are plans for this, but will take a while.
It's already possible a little bit to show multiple tracks on the map:
- Tap second button top left in the main screen
- Scroll down
- Expand "My Recorded Rides" section
- Select the folder you want to display the rides for
Hallo,
das geht gut mit GPX Studio.
https://gpx.studio/de
viel Spaß damit
Mex has reacted to this post.
Mex
