Color of marker text
Hey Guido,
just a simple request: I notice, that it is pretty hard to read the numbers in the via markers, as the markers are bright green and the numbers are white. If you have to read them it would be easier, if they were black or in an individual color.
Greetings Frank
Hi Frank, The color of the text is dynamically chosen based on the background color. It chooses black or white based on the luminosity of the background color (the color of your pins). This is not always perfect indeed. I will adjust this a little bit for the next update.
Meanwhile you can also change the color of your pins in Settings > Colors & Style. The pins adopt the same color as the Route Color.
Thank for the reply.
Maybe it is sufficient to have a user setting white text / black text.
Greetings Frank
