Changing routing options back to "balanced" doesn't work
pertaining to the Scenic App on MacOS: switching back the routing option from for example "curvy fast" to "balanced" doesn't work.
All auto-inserted via points persist and the route doesn't switch back to the previous layout without via points. The initial (balanced) route had 2 points, start and end.
Thnx for your answers
Hi Yo,
This is ‘as designed’. Scenic doesn’t know if you placed the via points manually or if they were generated by one of the curvy routing algorithms, so it won’t delete via points automatically.
In the power planner you can use the ‘undo’ button to go back to the previous state (before choosing curvy), or you can use the batch delete button (3rd button bottom left) to remove multiple via points, or, under the more button, you will find the ‘delete all vias’ button.
Thnx Guido,
didn't think about it this way.
regards
