changing route menu difficult to reach
Quote from Middelfrangge on 06.07.2025, 23:01Hi,
since the update to 4.20 and 4.21 I recognized that its really difficult tu reach the menu to planner mode to change something. Somewhen Guido wrote that swiping on the screen to move the map opens the menu that worked well in the past. Since version 4.20 swiping over my screen does not change anything but the map always jumps back to center my position. After 5-6 times it randomly works.
This occurs only when using Carplay and get out of Carplay to change the route, as soon as I have no phone connection to my Carplay screen it works well.
BTW, I also have the impression that zooming with BT controller buttons is slowed down since 4.21
Thomas
Thomas
Quote from Guido on 07.07.2025, 03:41Hi Thomas,
After you switch to another app on CarPlay, it can take up to 5 seconds (maybe even longer if connection with CarPlay is wireless) for full control to be given to Scenic on the iPhone. If you move the map in those first 5+ seconds, it's possible that the function that keeps the current position centered is not deactivated yet, and thus the map jumps back when a new coordinate is received. With this in mind, my recommendation is to wait at least 5 seconds after you've switched to another app on CarPlay, giving Scenic some time to build up the user interface on iPhone.
I didn't change anything to zooming with the bt controller in 4.21. Are you sure about that?
Hi Thomas,
Quote from Middelfrangge on 07.07.2025, 04:33Hi Guido,
I will try that again. Just recognized that with no Carplay connection it occurred as well and seems to be related to the direction I swipe on the screen. to the right it does not work, to the left I get the menu.
No, I am not sure about the BT controller….but I had more issues yesterday and need to find out first what was not changed…..the update was my first idea, but seems not to be the root cause if there was no change.
Thomas
Thomas
Quote from Guido on 07.07.2025, 04:35Hi Thomas,
You don't need to actually swipe from any side. Just moving the map a little bit should be sufficient to go to edit/overview mode. Maybe that helps.
Hi Thomas,
Quote from Middelfrangge on 07.07.2025, 05:59Guido, that might be true, but moving the map to the left or down does not work but moving up or to the right.
It does work as well to left and down, but not always…..seems to depend on speed and distance if moving the map. Up and right works in any speed or/and spdistance
Thomas
Thomas
Quote from Dae on 07.07.2025, 06:08For me, the menu appears regardless of how I move the map. It requires just the slightest drag on the screen to make it appear.
Just a data point @guidomm
Quote from Middelfrangge on 07.07.2025, 06:31o.k. here is the evidence
moving right with menu
moving down - no menu
moving left - no menu
Quote from Guido on 07.07.2025, 06:37Yes. I believe you Thomas. There must be something different in your setup. Maybe an accessibility setting or something. What is the binocular icon in the top right of your first screenshot?
Quote from Middelfrangge on 07.07.2025, 06:51that was just by mistake for tapping too long and scenic opened a marker to look around.
Quote from Guido on 08.07.2025, 05:01OK. I will investigate further in the coming week.
