Change waypoint sequence
@guidomm
I’ve created several routes in and around Amsterdam which are looped, meaning the start and finish begins/end from the same coordinates.
Although it’s possible to inverse the route to ride it backwards. I’ve bin wanting a feature to start the route somewhere midway without the scenic app directing you to the no. 1 waypoint first.
This would especially benefit the longer loops since it enables the rider to cut the ride into legs and continue where he’d left off another day.
In my opinion it would be great to select a waypoint from within the editor and change that into either start/finish or no. xx so that when you press confirm the route will be changed and all subsequent waypoints that follow the blue track are updated automatically.
This would also work for longer directional routes which due to the difficulty level or others circumstances weren’t able to be finished in time, on which riders might’ve decided to camp halfway.
Kindly let me know your what you think!
Some of this is already possible, but theobromine are a bit hidden at the moment I admit. In the route editor, under the ‘more’ button, there is an option to change the start/end point of a round trip.
Additionally, on the start screen, after you selected a route, you can choose which point in the route you want to be guided to. By default it’s the route start point indeed, but you can change that.
let me know if that covers your request or not
cheers and happy holidays,
guido
Hi Guido, this indeed answer my request for the missing feature. It was a bit hidden and therefore not clear to me, but now I know where to find it, there's no other place I could imagine within the app to make it more visible.
Thanks for pointing that out to me. Scenic 3 might improve with a small redo of the UI to improve UX, not that it is necessary to deviate too much from its current design.
En ook voor jou een fijne kerst toegewenst! 😉
