Change Routing Mode during Navigation
Quote from David_G on 21.05.2021, 04:58Hi,
Would it be possible to implement a function to change the routing mode during a Navigation?
This is possible in most apps at least in some form (maybe you have to pause and the resume the navigation to do that) but I have not found this in Scenic...Reason is if I for example plan my route using "short" in combination with Kurviger - supercurvy and I'm riding that planned route but then after some hours I get tired of all those very small roads and want to change to a more traditional routing but still keeping all my waypoints, that I've set.
Or also if I run out of time at want to allow motorways from now on to get to my destination on time without having to plan a completely new route.Currently I have to stop the navigation, go into route planning mode, save the route and then start a new Navigation with the new route together with a new Recording-session.
Thanks, David
Thanks, David
Quote from Guido on 21.05.2021, 08:01Hi David,
Should be possible in Scenic 3. I will add it to the list. Thanks for the suggestion!
Hi David,
Quote from AstridM on 30.05.2021, 16:57Quote from Guido on May 21, 2021, 08:01Hi David,
GuidoThanks Guido for considering this request. I was looking for it as well.
Ciao, Astrid
Ciao, Astrid
