Change order of stops made easier
In planning mode, is it possible to have an easier/quicker way of changing the order of single stops?
As far as I have seen, currently this is only possible by selecting a stop so the cursor sits at the correct spot, delete the stop and assign a new stop where you can define the previous stop.
Thanks and kind regards, David
There is a slightly quicker way.... when you tap on a stop, a bubble appears with 4 buttons.
From left to right these are the functions of those buttons:
  1. Edit the name of the stop
  2. Convert the stop into a via point
  3. Move the stop (you will be asked to move the map to the new location and tap OK)
  4. Delete the stop
Later in Scenic 3 I will also add a list of stops where you can easily change the order of stops and Vias.
Old Man Emu
I know the 4 options when tapping on a stop. Thats how I delete the stop to then make a new one with the new, corrected stop-number.
Or what exactly do you mean?
But when Scenic 3 has that list of stops where the order can be easily changed I am more than happy 🙂
Really looking forward to Scenic 3!!!
Sorry... I read your question wrong. I answered how to move the location of the stop, while you were asking about chaining the order of stops.
Ah yes, exactly 🙂
On one iPhone I use, I am stuck with Scenic 2 and having become very frustrated with the bizarre route it was creating, I realised that it was adding new stops/vias  BEFORE the others, instead of maintaining a sensible order. I then tried to reorder them, but was unable to.
Is it actually impossible to reorder a route in Scenic 2?
Quote from BiKenG on 06.07.2022, 04:18
I’m afraid so. The stop/via reorder feature  was added in Scenic 3.
David_G and Old Man Emu have reacted to this post.
David_GOld Man Emu
Thats so awesome, I love it!!
Have used that feature quite a lot in the meantime 😉
Thanks Guido!
Is there also a possibility to change the order during a navigation? In case one included a stop in the wrong order.
I think I found that option somewhere in the past, but I can't seem to find it now.
Indeed a similar feature existed during navigation in the past. But I removed it. It's still on the list to add it back, but will be a while I'm afraid. Until that time you'll have to remove and re-add in different spot manually through the map (in navigation edit mode). Double tap map during navigation to go to edit mode.
David_G has reacted to this post.
David_G
Minor item I noticed in the re-ordering dialog;
Start is shown with the Checkered Flag and End is shown with the Green Flag
Oh. Just tried this. You are right 🙄. This happens when a route is reversed.
Old Man Emu
So how do I reorder in Version 4? What am I missing? Same issue when using the App on my Mac.
Quote from TotalEgal on 09.11.2024, 17:31
Vias Anzeigen > Bearbeiten
