Change options between waypoints
Quote from BeameronaBeemer on 09.03.2022, 18:22Hello all,
Sometimes when I’m creating a route I like to lets say take the highway to get to somewhere, then later take the backroads to my destination.
It would be nice to have this option to select different route criteria between waypoints in one route.
Just an idea.
Thanks for all your hard work Guido.
John
Hello all,
Just an idea.
John
Quote from Guido on 09.03.2022, 18:28Hi John,
This item has been on the list for quite some time. It's however incredibly difficult to implement because the routing provider only allows for one routing mode per route. What I recommend is leave the routing mode on 'Balanced', 'Short' or 'Fast' (whatever you'll be using most) and force the route you want using via points.
This of course only works in areas you are more or less familiar with or areas where you can derive the route from the map. For a more automatic approach you could choose to generate a curvy route between start and finish, and then alter the generated routes (e.g. remove via points in the beginning where you want to take highways).
Hi John,
Quote from BeameronaBeemer on 09.03.2022, 19:43Thanks for the suggestions. I’ll give them a try..
