CarPlay with small issues
Quote from TwinRider65 on 11.07.2022, 06:04Thank you for the CarPlay function. I drove it for the first time this weekend. It worked very well on the whole. The announcements come at a very good time and are also not too much. The view of the track with zoom level is top.
However, some functions should definitely also work via CarPlay:
Entering a route. It seems to me that this is not yet implemented.
Routing criteria! I haven't found them in the CarPlay app yet.
There have been a few minor problems. After turning the ignition off and on again, it navigated but did not enter the route. The app had the route but no longer displayed distances and other stuff at the bottom. I then restarted the route.
In Dark mode on the motorbike, after switching to the Music app once, I saw nothing. The map was black. Everything else was visible and worked well. I then set the settings on the Honda to white and automatic mode to OFF. That was definitely necessary.
Many greetings, Andreas
Quote from Guido on 11.07.2022, 10:20Hi Andres,
You can choose a route or location through the 'where to' button:
Use this button to get to them:
This is indeed a bug. I hope to release an update this week, with a fix for this. Sorry about that.
Hi Andres,
