Forum breadcrumbs - You are here:Scenic ForumUsing ScenicCarplay question.
Carplay question.
I was thinking Scenic used to have a feature to navigate to the nearest waypoint on a route from your current location. Is that still available and can it be added to carplay?
Also, I just used scenic on carplay and couldn't get it to navigate a route from my current location. Is there something I'm missing?
Alan
I have seen similar. CarPlay UI does not provide the option to "join the route in progress" as the phone UI does.
This is a bug. Normally, this option is available through this button:
And then at the bottom you will find the "Guidance to route" options:
The bug is that this message shows even if you selected a pre-planned (previously saved) route. I will fix for the next update.
