Foxthorn on 09.04.2025, 11:14
Using 4.17 via carplay and I'm trying to pan the map by a touch and drag to move the map around but it is not working as expected - both while navigating and not navigating.
This same touch+drag to pan process works well for me when using Apple maps, google maps, Rever, RoadTrippers carplay apps. But with Scenic it does not pan but does seem to shift a tiny bit like it wants to pan but doesn't. If you bring up the directional arrow control, then that method will allow it to pan by touching the arrow controls but is not as convenient.
Is this a known issue or is this expected behavior?
