Forum breadcrumbs - You are here:Scenic ForumUsing ScenicCarPlay display glitches
Hi Guido.
a couple of issues that you maybe know about already, using CarPlay:
  • erratic move to dark display, sometimes it goes into dark mode in a tunnel and does not come back to light mode after, most of the time the display stays in light mode.  Maybe a good idea to have a override choice as 2D/3D, in fact it is more important to me than 2D/3D because a bright display at night is really ennoying
  • 2D/2D is a miss too.  When you stop for break and come back to the car the display goes back to 2D even if 3D is selected.  Also if you go to another app in CarPlay and come back to Scenic you are back to 2D.  Selecting 2D than 3D in the menu always fixes that
  • once i had the arrow showing your position disappear from the screen when i went off route.  I had to go to overview and then just exit and everything was fine
Thanks for the hard work, everything else went smoothly, i hope you can add the radars soon.
cheers,
Laurent
Thank you Laurent...I'm aware of the 1st and 2nd one. Will take a look at the 3rd one too. Thank you!
4.10 a display glitch occurred today;
I cannot repeat it 100% of the time but it seems to be related to switching between apps on CarPlay. I switched between Scenic and Waze and Scenic and Music. As stated is does not always happen please ignore the strobe lines on the screen.
I also found on longer drives with 4.10 and 4.09 that the navigation route line often got stuck, stationary but the voice instructions and turn dialog panels were still accurate.
Thank you. I'll look into it. I've had more reports on both issues.
