Carplay: "Adding Stopp" possibility to "Cancel" and show a map overview
I was on a little trip last weekend and Scenic worked very well.
One thing I found a little bit annoying.
I searched for a Gas station with "Adding a stopp"> Gasoline and got several results. I picked up the first station and I got three options to choose from. Because I had no possibility to look on the card in which direction the Gas station was, I wanted to cancel this, but there is no option for this. So I put it as the next stop and saw, that the gas station was some kilometers behind me.
The problem here is, that I cannot see in the results in which direction the Gas station is, so I'm stumbling in the dark.
When no route is active I can search for Gas stations and can choose the map symbol, so I can see where the next gas station is.
Perhaps this is not possible with carplay, but it would be a great help if it also will be possible in the "Add stopp" menu and if there would be the possibility to cancel adding the stopp.
Hope you understand what I mean.
Marc-Antón
Hi Marc-Anton,
Yes, I understand. You would visually like to see where the gas station is in relation to the route and the location, before you chose one of the options.
And/or at least have the possibility to cancel adding a stop.
This all on CarPlay.
I will add it to the feature request list.
Thank you!
