CarPlay 4.02 - Speed Indication Missing
Some screenshots below to show missing speed numbers in CarPlay when below the speed limit although present on the iPhone.  However, the numbers show correctly when you break the speed limit with the speed limit also showing correctly:
Most likely a font color issue in combination with appearance setting of the CarPlay system. Will investigate.
