Navigate with the cursor centered on the map without starting a trip
Desconozco si existe alguna posibilidad de que el cursor quede centrado en el mapa sin iniciar la navegación a un punto concreto o registro de viaje.
Sí. Si pulsas el botón central en la pantalla principal, puedes empezar a montar y el mapa se centrará.
Sin embargo, para tener la mejor vista del mapa, recomiendo iniciar una sesión de registrar de viajes. Puedes optar por descartarlo (no guardarlo) cuando hayas terminado.
Yes. If you tap the center button in the main screen you can start riding and map will be centered. However to have best map view I recommend to start a ride tracking session. You can choose to discard (not to save it) when you are finished.
Thank you very much for answering Guido. Perhaps I have explained myself wrong. What I was referring to is that if there is any possibility of navigating without starting a trip and that the cursor stays centered on the map and does not disappear from the map with the movement.
At this moment that possibility does not exist. I recommend to start a ride and then at the end you can simply discard it. Your data will not be saved.
Also, at the moment there is a bug in v3.10 (you can see version number at the bottom of settings). Because of this big your location is not always centered. Even in navigation or tracking mode. I will release an update this week to resolve it.
It seems to behave properly the first time Scenic is opened (motorcycle noise). After that the map orientation and centring seem to go astray.
By double tapping on the Navigation screen to pull up the edit options and then selecting the left hand icon, this seems to solve it.
Temporary measure.
Best wishes
Yes. That's correct Rods. Thanks for pointing out this temporary workaround. 👍
