PeteRT on 05.05.2022, 12:29
Just remember Scenic cannot move waypoints, the reverse function just changes the order of waypoints. If you have a waypoint on a multi-lane road, so here in the UK a dual carriageway or motorway, you will need to manually move the waypoint onto the correct side of the road, otherwise you will get strange loops. If the distance is much longer after reversal then this is probably the problem.
