Bug: voice does not match the direction indicated
Quote from FJC on 22.06.2020, 01:23Hi!
I've noticed for the two voices Catherine (Australian) or Anna (German) the last two days (I've just started using Scenic) that quite often the voice direction (e.g. turn "left") is opposite to the indicated direction on the phone (e.g. "turn right"). In all of my cases the sign direction on the phone was correct but the voice was wrong.
Have you experienced similar with these voices and are there any default English or German voices that are perhaps less buggy?
Thanks.
Regards,
frank
@guidomm
Hi!
Thanks.
Regards,
frank
Quote from Guido on 22.06.2020, 11:32Hi Frank,
I've noticed this myself too. It's not voice related though. Again this is routing provider related (one of the reasons why I'm looking into other providers). But I have noticed in my experience this only happens very rarely, when there are two turns relatively fast... it seems it takes the instruction of the 'next' rather the first upcoming one.
I'll see if I can find a workaround for this issue for the time being, because this indeed very disturbing.
Hi Frank,
Quote from Robertok on 24.06.2020, 10:10I suppose this relates to the route provider, but one several occasions when the planned route crossed itself, I got the wrong turning instruction and went way off course. Scenic instructed me to, in effect, rejoin the route I had already ridden instead of proceeding toward the finish. Very frustrating.
Quote from Guido on 24.06.2020, 10:12Quote from Robertok on June 24, 2020, 10:10I suppose this relates to the route provider, but one several occasions when the planned route crossed itself, I got the wrong turning instruction and went way off course. Scenic instructed me to, in effect, rejoin the route I had already ridden instead of proceeding toward the finish. Very frustrating.
Fully understand. Looking into a new map provider for Scenic 3 (next season). That's the only real way to resolve this.
Quote from SaschaOnTour on 26.06.2020, 12:25Same happened here ... rarely ...but 3 times on a 250km trip while riding through a confusing city street.
As I can remember it happened also in 2019 when I started to use Scenic. May this helps to find the root course...!?
Anyway ... after trying several apps in the past years ... Scenic is by far the best! Good job! 👍👍👍
