Forum breadcrumbs - You are here:Scenic ForumUsing ScenicBug after update
Bug after update
Hey! đź‘‹
After the last offline map update, I noticed that building colors,
I’ve noticed that the house colors are not being applied — only the outlines remain visible. Some custom colors are also missing.
I went to the editor and tried forcing the house color change, but it still behaves the same.
!After updating the map Before updating the map
Karlchen
Das habe ich auch festgestellt.
And this is since you updated your offline maps? Could you share your map style with me? (I just tried but can’t reproduce it with my style)
To share a style: https://scenic.app/forum/topic/scenic-4-custom-map-styles/#postid-12240
Erledigt.
bei Touren sehe ich auch nur die Gebäudeumrisse.
Beste GrĂĽĂźe
6201DF3A-69BE-4061-A56B-189B111B2C8C_491F16C7-BEF7-4365-BB40-95C2C732A0B7
Correct, it has been when updating the map, I have also seen that in the default style it does not happen to me, so something of my style does not like the update, greetings
Found, It is for this option, (land, artificial, residential). It is superimposed on the buildings
Karlchen
Perfekt.
Besten Dank 👍
Confirmed. It depends on the colors. Some color for residential “overwrites” the building color but other colors don’t. Strange. I will look into it.
Karlchen
Found the bug... will fix for next update.
Karlchen
