Bug adding via’s in gpx import
Quote from broadbeanprop on 26.10.2024, 05:50Hi Guido, today I imported a gpx file, and to make sure the route will follow the line completely I needed to add some via’s between existing via’s. This used to work great in version 3 but now wherever I use the button add via # it always adds it as via number 3. I’m currently on version 4.03, not sure in which version this bug first occurred. Also tested this in the normal planner without importing a gpx file and there it seems to work fine.
I hope this gives you enough info to reproduce this, if not I’m happy to help.
Kind regards and keep up the good work!
Quote from Guido on 26.10.2024, 06:28Thank you for the details. Should be enough to reproduce the problem.
Meanwhile, perhaps you can use the route timeline to re-order the via points after the new one was added in the wrong place.
Quote from broadbeanprop on 26.10.2024, 10:21Already managed by moving the next via’s forward, but that sounds like an easier workaround for the next import!
Quote from Guido on 12.11.2024, 11:48@broadbeanprop. Could you check if you still have this issue in v4.05?
If you don't have v4.05 installed yet (see version number at the bottom of settings), you can download through the app store: https://apps.apple.com/app/id1089668246
Quote from broadbeanprop on 12.11.2024, 14:45Hi Guido, sadly it doesn’t seem fixed yet. It does however always enter via number 4 instead of 3. Let me know if you’d like me to send you the gpx file, screenshots, or anything else that can help you.
Quote from Guido on 12.11.2024, 15:22@broadbeanprop, Yes... could you please send me the GPX and a screenshot showing where more or less you are trying to add the via?
If you prefer you can use the email button at the bottom of the help page.I haven't been able to reproduce this anymore, so there must be something I'm doing differently. Hope your GPX and screenshot will be able to help.
Quote from broadbeanprop on 12.11.2024, 15:55Since the route is close to my house and my location is on one of the screenshots I just sent you everything by email, let me know if you need more!
Quote from broadbeanprop on 27.11.2024, 11:17Just confirmed the issue is fixed in 4.06.
Thanks Guido!
Thanks Guido!
