Bodies of water show missing data
Quote from KatyTrooper1463 on 28.04.2025, 09:46Anyone having this issue around bodies of water or parks? It shows the box with the line through out it as if it has no data. The river is there, but the park is not. Strange. Looks like more of a map source issue than with Scenic. When riding through these areas on park roads, it’s very distracting to see where you are. Hoping they fix this….
e
e
Quote from Guido on 28.04.2025, 09:53Could you share the coordinates of the screenshot? (Long press on the map and choose “copy coordinates “ in the callout bubble. Then copy-paste the DEC coordinates here )
Quote from MjK on 28.04.2025, 11:04Hi @katytrooper1463, @guidomm,
This is an issue in the default map styles (light and dark) not showing correct data of the bear creek area near Houston.
Katy, for now when you switch to Satellite Hybrid mode you should be OK … as Guido will release the map customizer pretty soon, you will be able to fix such missing elements yourself
the following screenshot shows the lake/basin/bay area and the walking ways better - don’t take the colors I used as granted, I just experiemented what’s missing and used quite contrasting settings to find it..
Guido, the coordinates are 29.807562,-95.629854
hope this helps, Markus
