Forum breadcrumbs - You are here:Scenic ForumUsing ScenicBlank Map using Carplay
I am running Scenic v3.10, connected via Carplay on a 2018 Goldwing.  If I leave the scenic map for a phone call or to change music, the map is blank when I return to it.  Unplugging the phone and reconnecting (hence, restarting Carplay) solves the problem.  Finishing the ride appears to solve it also, but I need test it a couple more times to confirm that.
Anyone else having this issue?
Yes. It’s a big in v3.10. A new version with a fix  is currently awaiting Apple approval. With a bit of luck they approve tomorrow.
EmmEff and iSilentP have reacted to this post.
EmmEffiSilentP
