Begin at a certain waypoint / stop
Quote from clarkml72 on 02.03.2025, 10:55Now I may be missing the option or method here, so forgive me if that is so....In 3.x I could when starting a route have the option to "pick-up" the route at a certain numbered waypoint or stop. I don't see that option now. If I had to stop the route and then start it again it appears I have to click the trash for each waypoint up to the waypoint I wish to start at. That method is so much less than what we had in 3.x.
Is there a better way or is that it?
Mike
Mike
Quote from Guido on 02.03.2025, 12:36At the moment you can choose to be guided to the route start, or find your own way to the route (navigation will pick up when you reach the route). Later I will add to be guided to a waypoint of choice.
When you start a route on CarPlay, you get a question if you want to be guided to the route start. If you choose “no” there, Scenic will wait until you reach the route at some point and will pick up the route from that point.
On your iPhone, you can toggle between guiding to start or not with this button.
Quote from Karlchen on 02.03.2025, 23:47Hallo Guido,
ich habe heute morgen zum wiederholten Male auf CarPlay meine Route zur Arbeit begonnen.
Dabei bin ich wie immer auf No zum starten gegangen wie 1 höher auf dem Bild zu sehen.
zum wiederholten Male macht Scenic am Anfang alles richtig, will aber auf einmal mitten in der Tour doch zum Start,
Ich hoffe dass der Fehler bekannt ist und schnell behoben wird.
Beste Grüße
Karlchen
Hallo Guido,
Beste Grüße
Karlchen
